Swing bolt with support pin & Support Lug design For Slotted Flanges
RAJPT89
16
I am also looking for the calculation method for the Swing Bolt and PIN.
I believe these kinds of things fall under "good eningeering practice".
Mike
See AISC DESIGN EXAMPLES Version 13.0 525 pag. in pdf
Sorry, please see the last edition of AISC DESIGN EXAMPLES Version 15.1 2019 (985 pag in pdf).
Thank you r6155 for the reference.
Do you mean, examples D7 & D8 are applicable.
Can you kindly give full fledged calculation of the swing bolt closure with all parts?
RAJPT89. Can you kindly upload full drawing for better understanding.
@ DK44: Example D7 & D8 is only for tension. Wait the drawing from RAJPT89.
I have nothing of calculations for swing T-bolt.
Dear RAJPT89.
Could you upload drawings of the vessel with Swing Bolt closure you quoted with a sticky picture in your query.
