SS316L pipes internal Oxidation or Corrosion , Cleaning
we have an issue on site with the SS316L pipe internal joints areas "Oxidation / Corrosion" marks, need and expertise advice how this can be handled to clear the marks any other solution w/o proceeding with circulation cleaning, reason being asked for all the pipes are installed on-board of vessel. please advice.
REgards,
RK
RE: SS316L pipes internal Oxidation or Corrosion , Cleaning
Passivate the piping with 5% Nitric Acid. Circulate for half an hour to an hour.
Dear URKumar,
What is the pipe size? How did you find out the oxidation / corrosion marks in the internal portion of the welded joints?
Regards.
DHURJATI SEN
Kolkata, India
First you have to decide what it is you are doing and what you want for a result.
IF this is superficial then 5% nitric is perfect.
However if you have heat tint or other serious issues then you would have to actually pickle with Nitric/HF to remove it.
More background is needed.
P.E. Metallurgy
Dear Dhurjati sen,
my apology for late response, as im on year end holiday,
regarding your query for the pipe size it is 8" line and ship owner notified the black strains inside of the welded joint. this could happen deep inside of other joints as well, so to understand more, how this can be cleaned without circulating method.. ( need an advice if any other possibilities to rectify this issue ),
Ravi
Dear URKumar,
1. Ask the ship owner exactly how did he find out the black stains?
2. Carry out a boroscopic survey of a few weld joints at random from your side.
3. Find out what are the cleaning / circulation activities Operations would carry out before commissioning this piping.
Now you could reach a decision.
Regards.
DHURJATI SEN
Kolkata, India
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
White Paper - Moving to a Driverless Future
This white paper describes what we see as the best practices to support a sustainable engineering process for autonomous vehicle design. It exposes how to use simulation and testing in common frameworks to enable design exploration, verification and validation for the development of autonomous cars at a system, software and full-vehicle level to drive a mature product development process for automated driving. Download Now
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
