Is it possible in Abaqus to control DPI when we save images in TIFF? 1
mdama
Materials
GB
I wanted to save the images with TIFF format and 300 dpi (dot per inch). How can I modify the dpi?
When using File —> Print in Abaqus you can only specify DPI for PS and EPS file format. In case of TIFF it is only possible to change image size in pixels.
Thanks, So how can I make sure about DPI? I want 300 DPI? Is there any software you know I can do it?
Graphics editors such as GIMP (free) allow you to change PPI (pixels per inch) of an image. In GIMP you can do it using Image —> Print Sise. DPI refers to physical printers so it can’t be changed per se this way.
