Shell to Shell Contact
Hello All,
Thank you for everyone for the quick response.
I am using contacts between the shell elements.Checked the shell normal's before submitting the run.
Do I need to check any other options for better establishment of contacts?.
Kind regards,
RE: Shell to Shell Contact
Apart from checking surface orientation and accounting for shell thickness (which is done automatically by most contact formulations but should be also taken into account when positioning shell parts that are initially in contact) there are no special considerations for general cases of modeling contact between shells.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
