Contact US
Oxide layer on EDM cut Austenitic SS
How do you remove that dark oxide layer on SS
Portions of my parts are very narrow with small holes 3mm and I cannot quite get the TIG brush in the area Also ,,,
Tig brush creates heat which can warp slender parts
Can you recommend some powerful pickling ????
Thank You
RE: Oxide layer on EDM cut Austenitic SS
The parts are for very high vacuum work
Do I need to clean them at all ???
Will that oxide layer outgas or contaminate the vacuum in any way ???
We EDM a lot of small holes in austenitic SS for fuel injectors. We actually prohibit any secondary operation after EDM. These last for decades with no change in flow. There is moderate vacuum in the intake manifolds.
If there is zero concern about corrosion or fatigue then leaving the oxide and recast layer is OK.
In SS this is typically chemically cleaned by pickling. This will lightly etch the entire surface, depending on how you do it.
P.E. Metallurgy
There are chemical etch processes suitable for removal of EDM recast layer, which is typically <.0005". There are also abrasive flow processes like Extrude Hone that both remove the recast layer and improve surface quality.
Work and health took away our hot nitric and hyroflouic bath
And a good vacuum guy said you don't put EDM wire cut surfaces in high vacuum , so that recast has to be removed somehow
Hand work does it at a time cost
If you can't do it in house with pickling compounds, send it out. Electropolishing is cheap.
If the parts are small then you can do it with very small volumes of liquid.
You can buy pre-mixed pickle solution.
Tug's suggestion to send them out for a light electropolish is also very good.
P.E. Metallurgy
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
