Safely unplug a column sump using Nitrogen
CarterJohn11
Computer
IN
Our distillation column sump line is plugged up with residue material. We have tried backflushing the line by pumping backwards into it without success.
I also have tried pressuring up the column to atmospheric (column normally runs under vacuum) to try to push the material out but still no success.
I can get a bottle of Nitrogen and hook it up to a flange to pressure up the line and push the residue material back into the column to hopefully melt out, but before I do this, I want to know what is the safest way to go about doing this and minimizing the chances of knocking trays out or blowing a pressure relief.
What is the nature of the clog? Could you warm the pipe where the clog is to try to get that material to soften up? In general, I would try to blow away from the column internals if possible.
I can get a bottle of Nitrogen reverse phone lookup and hook it up to a flange to pressure up the line and push the residue material nba reddit back into the column to pcpartpicker hopefully melt out, but before I do this, I want to know what is the safest way to go about doing this and minimizing the chances of knocking trays out or blowing a pressure relief.
