Contact US
Element based surface tie not activated in Coupled Strucutural Acoustic Analysis.
I'm modelling a dam-foundation-reservoir system using acoustic elements to model reservoir domain.
I created an element based surface each for (Structure and foundation) and reservoir and used Tie Constraint to account for the interaction between the surfaces.
In my simulation results, I see that the tie constraints are not activated and the two surfaces move independently. It's also interesting to note that there's only a part of the surface tied between the dam and reservoir and the rest of it all is not activated.
I've attached an image of four different images. One highlighting the result with partially attached surface and other three showing the constraints and master and slave surfaces
Any help is appreciated. Thanks in advance.
RE: Element based surface tie not activated in Coupled Strucutural Acoustic Analysis.
Try using Adjust slave surface initial position option and modify Position Tolerance if computed value doesn’t work. When you set everything up you can run datacheck and verify internally created sets that show both connected and unconnected regions for tie constraint.
Hi, I tried position tolerance and adjusting initial slave position, but the problem still persists. Do you think it has something to do with the different mesh sizes being tied together? I don't think so. I'd like to know your opinion here.
Try further increasing position tolerance, it can be higher than the distance between surfaces. When there are large differences in mesh density of the tied surfaces, make sure that the one with finer mesh is assigned as slave surface.
Solved the problem by reducing the number of partition surfaces from eight to two and I still didn't understand the reason for the problem earlier. However, increasing position tolerance didn't seem to work. Thanks for the assistance
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
