Adaptive Meshing Failing
Hi all,
I'm having trouble getting an adaptivity study to run. Every time it runs I get the error:
"Sets corresponding to the active remeshing rules cannot be found in the specified ODB"
I'm not sure what's going wrong. I can run the adaptivity study if I use an entire part of the assembly, but I need to select regions of the part. I created a geometry set from within the assembly module of the faces I would like to remesh, and selected this from the remeshing rule, but then I get this error.
I am using Von Mises stress as the error indicator.
This also happens if I try and run the remeshing rule manually - I get the same error.
Has anyone else encountered this error and resolved the issue?
RE: Adaptive Meshing Failing
Try creating partition of the cell (3D) or surface (2D) around the region of interest and using it for remeshing.
Thanks for the suggestion!
I gave that a shot but it didn't fix the problem... but I did learn more about partitioning and cells vs. sets vs. surfaces! So that was helpful.
It ended up being that the field output request didn't contain the error indicator values. From everything I could find it seemed that this should be automatically requested by creating the rule, but it hadn't been selected or produced for whatever reason.
Does creating the remeshing rule usually automatically pull the error indicators or is this something I'll have to set every time?
Error indicator output is automatically written to .odb file so there's no need to request it separately. Thus if your analysis doesn't produce such output then there must be some error in the defined procedures. Check the generated text files (.msg, .dat) for warnings if these files exist.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
