Customized Cross/Tee 2
Vinay Pawar
9
Hello, if we designed a customized Cross/Tees whose overall dimensions are not as per API 6A. But bore size, ring grooves and connection holes are as per API 6A.
Can we monogramed such customized design?
Thanks in advance.
Hello Mr.Vinay,
For Monogramming as per API 6A, the equipment has to meet the complete requirement of the specification whichever is applicable for the equipment.
Unless the Specification allows to deviate the specific requirement, if you are deviating the same then API Monogram cannot be applied for the equipment.
You can refer API 6A Annex A, A3.1 clause for further understanding....
Thanks...
Dinu...
There are no secrets to success. It is the result of preparation, hard work, and learning from failure.
I do not understand the verb "to monogram" in this context ....
MJCronin
Sr. Process Engineer
