ASME Material certificate?
Hi everyone.
During material inspection, Material was rejected by customer due to ASME edition is not described on material certificate.
Chemical composition and mechanical property are met in accordance with ASME ed2017(same as design code edition).
Client requests to describe edition on material certificate otherwise they will reject material.
Could you advise where can I find the requirement in ASME code?(edition shall be mentioned on material certiticate)
and how to solve this problem?(I have asked to mill maker to put edition but they cannot do due to their system)
Please advise..
RE: ASME Material certificate?
PLease dont double post. I have red-flagged the other thread for deletion, as this subforum seems the most appropriate for your question.
Unless the testing requirements have changed between various code editions what is the difference between a material manufactured and tested in 2010, 2013, 2016, 2019 ?
The MTR is a record of mechanical and chemical testing and that doesn't change.
Ask your customer why they require a year on their reports.
Can't the mill just write a cover letter / cert of conformity to ASME VIII 2017. (I assume - "ASME" have a lot of codes & standards"
Your client sounds unreasonable - why not ask him where it states this as you can't find it anywhere.
I find it difficult to believe someone would "reject" materials on these grounds. Advise him or her of the impact (delay, cost etc) because he won't be able to justify it if he doesn't quote the specification item or code requirement which requires this and see what happens.
The customer is correct. Per either SA-6 clause 14.1.1 or SA-20 clause 19.1, the "year-date" of the specification shall be on the test report. I would think the mill should be able to issue a new MTR with this information added.
As noted by david339933 in this post (thread794-460803: ASME Code edition specified on MTR) :
Looking at Section II Part A Appendix II Table II-200-1 it is very often permitted to use previous editions of a material. Many materials allow edition as old as the mid-80's to be used. If the mill won't help you, perhaps your customer will accept that the material isn't that out of date.
I have no code section for reference to back up Geoff his comment, but it doesn’t seem strange that an edition of the applicable ASTM edition should be called out in the MTR.
The material certificates I have seen as good as always have dates shown. Same holds for EN material standards.
Why wouldn’t it? Why wouldn’t it be just as important as calling out the edition of the applied code on a GA drawing?
Thank you for your advice and providing information.
I have requested guarranty letter to mill maker which proof material was fabricated in accordance with ASME 2017ED
and will try to persuade customer to accept with this letter.
Just make sure you specify the correct/applicable ASME SA edition to the mill. I assume yore using VIII-1 2017 edt.; what material is in quesiton here? The 2017 edt of that specific ASME SA spec may not exist. E.g.: ASME IIA refers to ASME SA312-15 (even though there is a ASTM A312-19), in IIA ASME SA106 refers to the -08 edit (even though ASTM A106-19 exists), etc..
LSUUR,
This is a revision to my previous post which I now think does not relate to the relevant issue.
It is your responsibility as the buyer of the material to ensure the code/standard/specification listed on the MTR is correct prior to submitting documents to the Customer / Client for review.
If, the issues noted by Geoff13 and david339933 were not addressed by your company during document review then the Client / Customer is well within their rights to reject.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - A Guide to 3D Printing Materials
When it comes to using an FDM 3D printer effectively and efficiently, choosing the right material at the right time is essential. This 3D Printing Materials Guide will help give you and your team a basic understanding of some FDM 3D printing polymers and composites, their strengths and weaknesses, and when to use them. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
