Vertical Load Bearing Single Wythe Brick Veneer
I have a client that wants to use the following 2 details for a subdivision. Some houses may be 2 story. Detail A is the one that bothers me. They want the single wythe brick veneer to align with the wood stud wall. I already see their vertical bar needs to embed into the foundation but the concept of making the brick veneer load bearing seems to have several potential flaws. Even if they lay the brick while laying the block, I see slight rotation of the foundation possibly losing the bearing of the upper header block on the brick below. This could allow the header block to shear off. At the same time, I see making the detail where it is not reliant on the brick below difficult also.
Any thoughts or suggestions as to how to achieve this detail. Since they want 1 detail for all circumstances, it is not possible to avoid uneven soil bearing completely. I am currently assuming the T.B.D. will be set at 40" max. I am not really concerned about the quality of workmanship from the Client.
RE: Vertical Load Bearing Single Wythe Brick Veneer
Looks like your slab is sitting on a shoe block that is straddling the CMU and brick. How about losing the shoe block and doing a turn-down slab onto the foundation wall that cantilevers the 4.5" to carry the wall?
https://www.eng-tips.com/viewthread.cfm?qid=457520
The stud wall, I presume, is bolted down to the turn-down (not shown) and the turn-down is anchored to the foundation, but eccentric.
A very awkward detail for sure.
I'd worry about:
1. The true uplift resistance - both overall net uplift and braced panel or shear wall overturning uplift.
2. The eccentricity between stud wall anchorage and foundation rebar for uplift.
3. Clay brick below grade slowly degrading under wet-dry conditions and/or possible freeze-thaw conditions....not sure if in cold country or not.
4. The embedded wood sill directly above the brick creates an eccentricity in the stud-to-brick bearing....possibly creating an outward bow in the brick eventually.
5. The embedded wood, even if treated, might be subject to rot and/or termites getting up into the stud wall easily.
