VB api String parameter
TiagoFigueiredo
Industrial
PT
I'm developing an API to fill the parameters of some parts. Till now I'm able to fill the parameters of type Real Number. But for String parameters, I'm unable to change it's value by the VB API.
Any idea of how to do it?
This is the code
Code:
        Dim asynconn As New pfcls.CCpfcAsyncConnection
        Dim session As pfcls.IpfcBaseSession
        Dim Parametro As IpfcBaseParameter
        Dim ParamValue As IpfcParamValue
        Dim pobj As IpfcModel 'As IpfcModelItem
        Dim sel As IpfcSelections
        Dim selopt As IpfcSelectionOptions
        Dim comprimento As Double = 0.0
        Dim Descricao As String = ""
        Dim Mitem As CMpfcModelItem
        Dim pv1 As IpfcParamValue
        conn = asynconn.Connect("", "", ".", 5)
        session = conn.Session
        'model = session.CurrentModel
        model = session.GetActiveModel
        window = session.CurrentWindow
        'mdlname = session.CurrentModel.FileName
        mdlname = session.GetActiveModel.FileName
        Work_dir = session.GetCurrentDirectory
        selopt = (New CCpfcSelectionOptions).Create("part")
        selopt.MaxNumSels = 1
        sel = session.Select(selopt, Nothing)
        'pobj = sel.Item(0).SelItem
        pobj = sel.Item(0).SelModel
        Dim aa = pobj.FullName
        ' pobj.DisplayInNewWindow()
        'Dim_Y
        Parametro = pobj.GetParam("DIM_Y")
        ParamValue = Parametro.Value
        comprimento = ParamValue.DoubleValue
        MsgBox(comprimento)
        Mitem = New CMpfcModelItem
        'pv1 = Mitem.CreateDoubleParamValue(CDbl(22222.0))
        pv1 = Mitem.CreateDoubleParamValue((33333.0))
        Parametro.Value = pv1
        'Descricao_POR
        Parametro = pobj.GetParam("DESCRICAO_POR")
        Descricao = ParamValue.StringValue
        MsgBox(Descricao)
        Dim TEXTO As String = "AAAA"
        pv1 = Mitem.CreateStringParamValue(TEXTO)
        Parametro.Value = pv1 'HERE IS THE ERROR
        conn.Disconnect(1)
        Me.Close()
    End Sub
Tiago Figueiredo
Tooling Engineer
Youtube channel:
