1.8Mod 30PA spline - what standard is that?
spigor
269
Recently I have come across a 1.8Mod 30PA spline. Does anybody know, what standard is that, if any?
Thanks!
Hi Spigor
did you get it ?
I believe its a special. designers mixing it up, hard to reverse engineer.
did you measure the major, minor, and the base pitch?
what application?
Here are the measurements:
T=19
da=31.725 mm
df=34.978 mm
Yes, it's an internal.
1.8M 30PA look good when checked on a Precision Measuring Center.
