Contact US
Nitronics 60 foil
Nitronics 60 foil
Nitronics 60 foil
We have been using Nitronics 60 (UNS S21800) foil for over 30 years. It gets processed through multiple stages from the ingot to the finished size. The people who do the finishing passes say they are no longer able to get it. They buy it in coils that are 0.062" thick by 13.5" wide by 150 feet minimum. They say the mills are no longer producing flat stock, only bar products. Does anybody know of a source for this?
RE: Nitronics 60 foil
Try Carpenter. This is not a very popular grade for Carpenter either, but they make both bar stock and Strip product, large quantity (heat lot quantity) only.
Carpenter makes their proprietary Gall-Tough Plus which lists UNS S21800 on their data sheet but they take a lot of liberties with the composition limits. I'll have out purchasing contact them though, we buy a lot from them.
@dgallup: yes the internal name is Gall-Tough Plus because it exhibits superior self-mated galling and metal-to-metal wear resistance. The composition fully meets limits for UNS S21800 (ASTM A479) or S20162! if you have special chemistry requirements outside of UNS 21800, Carpenter could also consider to take exceptions.
Th Gall-Tough Plus spec sheet I downloaded yesterday does not meet UNS S21800.
Gall-Tough Plus allows
0.15% max Carbon vs 0.10% max
0.04% max Sulfur vs 0.03 max
4 to 8% Manganese vs 7 to 9%
6 to 10% Nickel vs 8 to 9%
16.5 to 21% Chromium vs 16 to 18%
2.5 to 4.5 Silicon vs 3.5 to 4.5%
Data sheet is often different from spec. or limits. Carpenter Gall-Tough Plus internal chemistry fully meets S21800, no even need to deviate from standard melting process
Looks like we will be able to get from Electralloy.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
