Linear Buckling
Linear Buckling
Linear Buckling
Trying to set up a buckling analysis of a flying structure (so no BC). I set the loads and request 5 eigenvalues. I get only one eigenvalue and I'm not sure how to interpret the information since the only eigenvalue I get is 10 power -11 so basically 0. I'm not sure how to read these info and to change the model in case.
RE: Linear Buckling
Your first eigenvalues are probably (close to) zero. Those are the rigid body modes. Request more eigenvalues or set a lower limit of 1.
RE: Linear Buckling
No matter how many I request, I get only 1 eigenvalue and it's basically 0.
RE: Linear Buckling
Can you share some basic information (no need for details) about your model - what kind of structure it is and how it’s loaded ? Maybe you could use inertia relief but that only makes sense if your structure is accelerating.
RE: Linear Buckling
It's a flying truss structure with 2 rotors: front and rear. So no boundary conditions. You can imagine it as a simple beam, loaded vertically at both ends with the same load (generating same lift from both rotors).
I didn't know inertia relief could work in these problems, I try now.
Thank you!
EDIT: Inertia relief in not allowed for buckling.
RE: Linear Buckling
Inertia relief can be used in eigenvalue buckling analyses but apparently it requires BCs and other loads anyway so it won’t help in this case. It looks like you will have to define some boundary conditions for you model to perform this simulation. Also I would definitely switch to beam elements if you use truss ones.
RE: Linear Buckling
I have beams only. I have to think something different at this point because haven't been able to find a solution
RE: Linear Buckling
Apart from boundary conditions, which in this case will be hard to define in such way that they don’t change the solution a lot, you can try with so called soft springs. This technique is often used instead of inertia relief for free floating models. Add springs will low stiffness in the directions of rigid body motions.
RE: Linear Buckling
I'll try that, thank you for the hints. As a matter of fact I have a model ready with springs at the wheels for a parametric study of the landing gear stiffness.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
