ramihabchi
hi,
In case monolothically casted drop beam in a solid slab are we always able to consider it as a T-beam?
Are the transverse reinforcement in this case at top of slab used to make the T-beam section as rigid?
Why don t we always, in the mentioned case at the top,consider beam as T beam.I mean it would resist more bending moment with reduced deflection with lesser reinforcement.and slab moments will be the same,therefore reinforcement would be the same(except transverse reinforcement mentioned of course)
