is it possible to use SA105 material for tube sheet in shell & tube heat exchanger ? 1
gh61
DE
thaks a lot
gh61, welcome to Eng-Tips. Please note that it is considered "bad form" to double post. Please consider "red-flagging" (Report) this post and asking that it be removed. The discussion can then continue in the ASME forum. Thanks in advance
as per clause 1 (scope) of SA 105, Tube sheets are not included within the scope of SA 105 Specification.
What is the Code of construction?
