Applying ductile damage and damage evaluation for tensile test specimen
Recently, i have model a tensile test on abaqus applying elastic and plastic properties. And the FEM results were very accurate. I'm wondering how to apply the ductile damage and damage evaluation to this model.
RE: Applying ductile damage and damage evaluation for tensile test specimen
Among various damage models available in Abaqus there is a ductile damage initiation criterion. It can be specified in CAE using material editor: Mechanical —> Damage for Ductile Metals —> Ductile Damage. There you have to specify equivalent plastic strain at damage initiation and its dependence on stress triaxiality and strain rate (optionally also temperature and predefined field variables). To define this in the input file use *Damage Initiation, criterion=Ductile.
Damage evolution for ductile metals can be defined in the same window. Select Suboptions —> Damage Evolution and choose the type (Displacement or Energy). For the first type you have to provide the value of effective plastic displacement at failure (measured from the time of damage initiation). For the second type specify the value of fracture energy. This can be also defined in the input file using *Damage Evolution, type=Displacement or *Damage Evolution, type=Energy.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
