Hi all,
I'm fairly new to Abaqus.
For the sake of automating tedious operations of selecting entities i'm looking for a way to make automatic selection of nodes/faces/edges by either location and/or it's size.
I'd like to run few command lines to do things like for example:
pick all nodes located in between 0-3 degrees of THETA on a cylindrical CS and then remove from the selection all nodes from of Z coordinate less than 5 and save all the selected nodes to a set.
I'll appreciate any kind of help.
Thanks!
Thanks!
