WPB elbow tensile test
Dear friends
we perform a tensile test on a sample from a batch of A234-WPB elbow to ensure that the data in certificate has mentioned right.
result for tensile and yield strengh was in the range of ASME SecII tables.
But the elongation was 3% lower than the minimum requirements.
As you know because of the elbow curvature , we have to straighten the sample. then we sent it for machining to prepare the tensile test specimen according to SA-370.
what is your opinion about this issue ? is this reduction in elongation a cause for rejection?
Does the cold work which we have done on the sample, has any effect on elongation?
what would you do in this situation?
Best regards
Best regards
RE: WPB elbow tensile test
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
Bob
The gage length, the strain rate, the size of specimen, and direction of deformation/cold work will all affect EL.
Measurement on part and on as-shipped bar/plate stock can make a difference as well.
