ATF merox caly treater DP Issue
IN
thread483-199149
Hi guy... With reference to Kero Merox clay treater high differential pressure issue
In my plant which is ATF merox, In clay treater same issue is noticed...from past 15days clay treater DP is got increased and it is observed that there was sum pressure surge causing this high DP... We are in doubt what was the actual cause.... Water carry over due the surges or anything else????
