Davit Arm Calculations 2
Re-Eng Rana
4
Hi, I'm working through calculations for a davit arm design, from Pressure Vessel Design Manual 3rd Edition by Dennis R. Moss, to check against my calculations. The web link as follows is best for descibing it: Questions:
1. Has anyone gotten effective results from it?
2. Section 3.1 Bending Moment, what is the 'l' (lower case L) in M = lV, contributed from: Pressure Vessel Handbook 12th Edition by Eugene F. Megyesy?
3. Does any one have better analytical analogy for Type 1 davit arm design?
Thanks heaps.
Referencing Eng-Tips closed post: thread794-332471
Avoid calculations, try to use standard davit as per PIP VESSEL STANDARD DETAILS.
Have UG-22 Loadings been considered? What about the attachment welds? Any fillet welds been evaluated in the shear?
@ oknow
Have you the PIP VESSEL STANDARDS DETAIL?
You guys are gun! Thank you for your responses. I haven't had to engineer pressure vessels before and I am not familiar with the codes you're referring to, and I don't have the PIP Vessel Standards Detail. My main concern is the height of the davit that I can go to with the lightest SHS steel...hence the calcs. Welds aren't a problem. If you can please direct me closer (Section, page number, web site) to what you're both referring to in the documents you mention, that would be so awesome as I have not found anything useful yet (I'll keep working at it).
r6156..I do not have that PIP Vessel Standard but from what I viewed on a search seems to be Procedural type of document to which I am not sure who would use or how it is incorprated into ones Quality System. Just how it would support the design of the davit for ASME UG-22 Requirements. The 2019 revision to UG-44(b) requirements may also impact the davit attachments
Re-Eng Rana, please clarify: Davit is attached to a pressure vessel, or no? "Sand bagging"?
Mike
Hi Mike, SnTMan,
The davit isn't attached to a pressure vessel. In this case it is similar to sand bagging..it's a 1 tonne lifting frame...6m tall.
oknow and r6156, I cannot find anything useful in the documents you have suggested, sorry. But Maybe i don't have access to it all.
Thanks heaps!!
An update for all these champions for helping me, and for future designers, the formulas I was following, noted in my first post, are correct. The one thing I did not have correct was the strength of the steel SHS member mast. It required to be 350MPa as a minimum, not the 250MPa that I was using.
I really appreciate having others out there who gave me support. Thank you.
All thickness in PIP Davit are based on 36 ksi Yield Strength.
Also see Pressure Vessel Design Manual by Dennis R. Moss, 4TH Ed.
