Provision spares with confidence
shg4421
Last year I asked a question in about a function to give the number of spares required for a lifetime purchase given only the number of operating hours and failures to date, the operating hours remaining, and the confidence level. -- something I thought would be pretty common, but apparently not. In the end, I wrote a VBA function for Excel to do just that via numerical integration:
= NumSpares(HrsSoFar, nFail, HrsToGo, ConfMin, [Stats])
E.g.,
=NumSpares(100000, 0, 150000, 95%) returns 1
=NumSpares(100000, 0, 150000, 95%, 1) returns
1 98.4% 27,109 3,949,789[/tt]
... which means 1 spare gives 98.4% confidence and shows the MTBF integration limits.
=NumSpares(100000, 0, 150000, 95%, 2) returns
0 88.9% 27,109 3,949,789
... which means 0 spares gives 88.9% confidence and the second line is as described above. The output lists all results from 0 spares to the number that achieves the required confidence.
I'm happy to post the code if anyone want to give it a test drive and compare the results to any alternative method.
Sure, I'd be interested, but I'm bothered by the seeming lack of an input for the MTBF itself, although you apparently do something with MTBF.
TTFN (ta ta for now)
The true MTBF is unknowable; that was the point. The code integrates over the 95% confidence interval (the constant [tt]MTBFConfInt[/tt] in the first function).
Here's the code:
Code:
Function NumSpares(HrsSoFar As Double, nFail As Long, _
                   HrsToGo As Double, ConfMin As Double, _
                   Optional iStats As Long) As Variant
  ' shg 2018, 2019-0706
  ' Calculates the number of spares required such that an LRU that has had
  ' nFail failures in HrsSoFar will not exceed NumSpares failures in HrsToGo
  ' (beyond the failures that have already occurred) with confidence ConfMin.
  ' HrsSoFar and nFail are assumed as time-truncated (vs failure-truncated) values
  ' iStats  Return
  '   0     number of spares required
  '   1     numbers of spares, resulting confidence, and integration limits
  '   2     spares {0,1,2,...}, resulting confidence, and integration limits
  Const m           As Long = 100       ' number of MTBF steps
  Dim r             As Double           ' MTBF geometric ratio
  Dim i             As Long             ' index to all arrays
  Dim conf          As Double           ' confidence of having nSpare or fewer failures in HrsToGo
  Const MTBFConfInt As Double = 0.95    ' MTBF Confidence Interval
  Dim MTBFMin       As Double           ' low limit of integration
  Dim MTBFMax       As Double           ' high limit of integration
  Dim adMTBF(0 To m) As Double          ' geometric progression of MTBFs spanning MTBFMin to MTBFMax
  Dim adPrb1(0 To m) As Double          ' prob of LRU having exactly nFail failures in HrsSoFar at this MTBF
  Dim dPrb1Int      As Double           ' numerical (trapezoidal) integral of adPrb1 over adMTBF
  Dim adPrb2(0 To m) As Double          ' prob of LRU having nSpare failures in HrsToGo at this MTBF
  Dim col           As Collection       ' collection of results
  If HrsSoFar <= 0# Then
    NumSpares = "HrsSoFar > 0!"
  ElseIf HrsToGo <= 0# Then
    NumSpares = "HrsToGo > 0!"
  ElseIf nFail < 0& Then
    NumSpares = "nFail >= 0!"
  ElseIf ConfMin <= 0# Or ConfMin >= 1# Then
    NumSpares = "0 < ConfMin < 1!"
  Else
    ' build an array of MTBFs and the probabilities of having
    ' nFail failures in HrsSoFar at those MTBFs
    Set col = New Collection
    With WorksheetFunction
      If nFail = 0 Then
        MTBFMin = ConfidenceLimit(HrsSoFar, nFail, MTBFConfInt, 4)
        ' there is no uper limit, so pretend there was one failure
        MTBFMax = ConfidenceLimit(HrsSoFar, 1, MTBFConfInt, 5)
      Else
        MTBFMax = ConfidenceLimit(HrsSoFar, nFail, MTBFConfInt, 5)
      End If
      r = (MTBFMax / MTBFMin) ^ (1# / m)
      For i = 0 To m
        adMTBF(i) = MTBFMin * r ^ i
        adPrb1(i) = .Poisson_Dist(nFail, HrsSoFar / adMTBF(i), False)
      Next i
      ' calculate the integral
      dPrb1Int = dDefInt(adMTBF, adPrb1)
      NumSpares = -1
      Do While conf < ConfMin
        NumSpares = NumSpares + 1
        ' calculate the product and integrate
        For i = 0 To m
          adPrb2(i) = adPrb1(i) * .Poisson_Dist(NumSpares, HrsToGo / adMTBF(i), False)
        Next i
        conf = conf + dDefInt(adMTBF, adPrb2) / dPrb1Int
        col.Add Item:=VBA.Array(NumSpares, conf, MTBFMin, MTBFMax)
      Loop
    End With
    Select Case iStats
      Case 0  ' just the required spares
        NumSpares = col.Item(col.Count)(0)
      Case 1  ' required spares, confidence, and mtbf limits
      Case 2  ' 0 to required spares and associated confidence
        Dim avOut   As Variant
        ReDim avOut(1 To col.Count)
        For i = 1 To col.Count
          avOut(i) = col.Item(i)
        Next i
        NumSpares = avOut
      Case Else
        NumSpares = Array("iStats {0|1|2}!", "", "", "")
    End Select
  End If
End Function
Function DefIntegral(vY As Variant, vX As Variant) As Variant
  ' shg 2018
  ' UDF wrapper for dDefInt
  Dim adX()         As Double
  Dim adY()         As Double
  If Not bMake1D(vX, adX, 1) Then
    DefIntegral = "X!"
  ElseIf Not bMake1D(vY, adY, 1) Then
    DefIntegral = "Y!"
  ElseIf UBound(adX) <> UBound(adY) Then
    DefIntegral = "XY!"
  Else
    DefIntegral = dDefInt(adX, adY)
  End If
End Function
Function dDefInt(adX() As Double, adY() As Double) As Double
  Dim i             As Long
  ' shg 2018
  ' VBA only
  ' returns the trapezoidal integral of adY over adX
  For i = LBound(adX) + 1 To UBound(adX)
    dDefInt = dDefInt + (adX(i) - adX(i - 1)) * (adY(i) + adY(i - 1)) / 2
  Next i
End Function
Function bMake1D(av As Variant, ad() As Double, Optional iBase As Long = 0) As Boolean
  ' shg 2014
  ' VBA only
  ' Returns a 1D iBase-based array of the values in av, which can be a
  ' column or row vector, a 1D array, or a scalar
  Dim rArea         As Range
  Dim cell          As Range
  Dim nOut          As Long
  Dim i             As Long
  Dim iLB1          As Long
  Dim iUB1          As Long
  Dim iLB2          As Long
  Dim iUB2          As Long
  If TypeOf av Is Range Then av = av.Value2
  Select Case NumDim(av)
    Case 0
      Select Case VarType(av)
        Case vbDouble, vbLong, vbInteger, vbSingle, vbByte
          ReDim ad(iBase To iBase)
          ad(iBase) = av
          bMake1D = True
      End Select
    Case 1
      iLB1 = LBound(av)
      iUB1 = UBound(av)
      ReDim ad(iBase To iBase + iUB1 - iLB1)
      For i = iLB1 To iUB1
        If VarType(av(i)) = vbDouble Then
          ad(i - iLB1 + iBase) = av(i)
        Else
          GoTo Oops
        End If
      Next i
      bMake1D = True
    Case 2
      iLB1 = LBound(av, 1)
      iUB1 = UBound(av, 1)
      iLB2 = LBound(av, 2)
      iUB2 = UBound(av, 2)
      If iUB1 <> iLB1 And iUB2 <> iLB2 Then
        ' one dimension must be a  single element
        GoTo Oops
      ElseIf iLB2 = iUB2 Then
        ' column vector
          Select Case VarType(av(i, iLB2))
              ad(i - iLB1 + iBase) = av(i, iLB2)
            Case Else
              GoTo Oops
          End Select
        Next i
        bMake1D = True
      Else    ' iLB1 = iUB1
        ' row vector
        ReDim ad(iBase To iBase + iUB2 - iLB2)
        For i = iLB2 To iUB2
          Select Case VarType(av(iLB1, i))
              ad(i - iLB2 + iBase) = av(iLB1, i)
            Case Else
              GoTo Oops
          End Select
        Next i
        bMake1D = True
      End If
  End Select
Oops:
End Function
Private Function NumDim(av As Variant) As Long
  Dim i             As Long
    If av.Count = 1 Then NumDim = 1 Else NumDim = 2
  ElseIf IsArray(av) Then
    On Error GoTo Done
    For NumDim = 0 To 6000
      i = LBound(av, NumDim + 1)
    Next NumDim
Done:
    Err.Clear
  End If
End Function
Function ConfidenceLimit(HrsSoFar As Double, nFail As Long, _
                         conf As Double, iType As Long) As Variant
  ' shg 2019
  ' Returns the specified MTBF confidence limit
  ' [URL unfurl="true"]https://reliabilityanalyticstoolkit.appspot.com/confidence_limits_exponential_distribution[/URL]
  ' [URL unfurl="true"]https://www.itl.nist.gov/div898/handbook/apr/section4/apr451.htm[/URL]
  ' iType       limit               data
  '   0     lower one-sided   failure-truncated
  '   1     lower two-sided   failure truncated
  '   2     upper two-sided   failure truncated
  '   3     lower one-sided   time-truncated
  '   4     lower two-sided   time-truncated
  '   5     upper two-sided   time-truncated
  Dim alpha         As Double
  If nFail < 0& Or conf <= 0# Or conf >= 1# Then
    ConfidenceLimit = CVErr(xlErrNum)
  Else
    alpha = 1# - conf
      Select Case iType Mod 6
        Case 0  ' lower, one-sided, failure-truncated
          If nFail = 0 Then
          Else
            ConfidenceLimit = 2# * HrsSoFar / .ChiSq_Inv_RT(alpha, 2# * nFail)
          End If
        Case 1  ' lower, two-sided, failure truncated
          If nFail = 0 Then
          Else
            ConfidenceLimit = 2# * HrsSoFar / .ChiSq_Inv_RT(alpha / 2#, 2# * nFail)
          End If
        Case 2  ' upper, two-sided, failure truncated
          If nFail = 0 Then
          Else
            ConfidenceLimit = 2# * HrsSoFar / .ChiSq_Inv_RT(1# - alpha / 2#, 2# * nFail)
          End If
        Case 3  ' lower, one-sided, time-truncated
          ConfidenceLimit = 2# * HrsSoFar / .ChiSq_Inv_RT(alpha, 2# * nFail + 2#)
        Case 4  ' lower, two-sided, time-truncated
          ConfidenceLimit = 2# * HrsSoFar / .ChiSq_Inv_RT(alpha / 2#, 2# * nFail + 2#)
        Case 5  ' upper, two-sided, time-truncated
          If nFail = 0 Then
            ConfidenceLimit = "(none)"
          Else
            ConfidenceLimit = 2# * HrsSoFar / .ChiSq_Inv_RT(1 - alpha / 2#, 2# * nFail)
          End If
      End Select
    End With
  End If
End Function
The calculated upper bound seems a bit high to me. Shouldn't 95% reliability at 100,000 hrs result in an MTBF of 1.95 million hr, just from -100000/ln(0.95)?
3949789 hr MTBF results in exp(-100000/3949789) = 97.5%, which looks like that's because of the two-side choice
Right; it's a 95% two-sided confidence interval -- 2.5% above and below. The function [tt]ConfidenceLimit[/tt] computes one- or two-sided limits for time- or failure-truncated data.
Thanks for looking.
I guess the question is whether that's appropriate; seems to me that reliability is always one-sided in a practical sense, since we never really care about the lower side, as that's often buried by the infant mortality.
The function integrations over a ratiometric scale from the low limit to the high limit. I reckon it could integrate from a smaller value, but not zero. I don't think it would change the answers out to several decimal places, but it's a valid point, thanks.
I'd be very interested if you compared and posted results with any other source you have.
