Extracting filter coefficients from fdatool IIR filter object
Jef92
Materials
Jul 30, 2017
4
Hi everyone,
I have designed an IRR filter in fdatool but since I can't export the coefficients as a vector into the workspace, I exported the filter as an object. The problem is that when I open the object, I have 3 arrays stored in it (ScaleValues, States and sosMatrix). Please, could someone exlplain me the difference between each array and, more importantly, how I can extract the filter coefficients from my IRR filter ? Also if you could write down links to official sources/documentation, it would amazing. Please any help would be really appreciated. Thank you in advance.
P.S. I am converting my structure to Direct-Form 1since, supposedly, it gives the coefficients for the ideal IRR filter or is, at least, more accurate but I am also not sure about it and if soemone could also explain me what it is exactly, it would be greatly appreciated.
Also, I am using a Lowpass Chebyshev Type II filter for my IIR. Thank you.
From my 10 seconds of Googling and the FDA docs, the filter coefficients are supposedly displayed in the Filter Specifications region of the GUI (upper right-hand section of the fda tool GUI)...
Dan - Owner
