Contact US
420 SS Heat Treatment
This alloy can have a variety of heat treatments applied: Process anneal, full anneal and of course hardened and temper.
However, normalizing is not recommended for this alloy. Why not?
RE: 420 SS Heat Treatment
Normalizing , air cooling, is the same as a quench for 13 Cr . Quench without temper is likely to give low toughness. I usually sub-critical annealed to soften it because a full anneal requires hours to cool to 1000 F.
That you for advise guys - all makes sense.
Do you mean normalization alone? Obviously without the temper, you will lose your toughness and corrosion.
If you mean the cooling rate, air cool vs oil or water cool, normalizing may give you insufficient cooling rate to get full martensitic for a large cross section, then slower cool will give you some grain boundary carbide leading to intergranular corrosion. this can worsen the effect of H2 embrittlement.
being said, normalization can sometimes be used for grain refinement.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
