Savitzky-Golay filter
cherryg222
KR
Recently I came across the versatile Savitzky-Golay filter on a different forum. The creator for the code Conrad Hoffman has kindly shared the code, as below.
This filter is very useful for smoothing data which is voluminous and has too many spikes. Try it.
Sub SG_five()
'5 Point Savitzky-Golay Smoothing Filter
'Multiple InputBoxes are used so the macro is self-contained.
'Note that this is a fixed output calculation and does not update if input data is changed.
On Error GoTo NotValidInput
Dim i As Integer 'counter
Dim Lrow As Integer 'low cell of data column
Dim Urow As Integer 'high cell of data column
Dim Ic As Integer 'column NUMBER for input data
Dim Cnum As Integer 'column NUMBER for output
Ic = InputBox("Enter column NUMBER of input data (A=1, B=2 etc.)")
Lrow = InputBox("Enter row number of first data cell.")
Urow = InputBox("Enter row number of last data cell.")
Cnum = InputBox("Enter column NUMBER for output (A=1, B=2 etc.).")
'5 point S-G coefficients are -3, 12, 17, 12, -3 and the divisor is 35
For i = (Lrow + 2) To (Urow - 2)
Cells(i, Cnum).Value = (-3 * Cells(i - 2, Ic).Value + 12 * Cells(i - 1, Ic).Value _
+ 17 * Cells(i, Ic).Value + 12 * Cells(i + 1, Ic).Value - 3 * Cells(i + 2, Ic).Value) / 35
Next i
Exit Sub
NotValidInput:
MsgBox ("Non valid entry- terminating.")
End Sub
Sub SG_eleven()
'11 Point Savitzky-Golay Smoothing Filter
Dim Lrow As Integer 'lower cell of data column
Dim Urow As Integer 'uppper cell of data column
Dim Cnum As Integer 'column number for output
For i = (Lrow + 5) To (Urow - 5)
Cells(i, Cnum).Value = (-36 * Cells(i - 5, Ic).Value + 9 * Cells(i - 4, Ic).Value + 44 * Cells(i - 3, Ic).Value + 69 * Cells(i - 2, Ic).Value _
+ 84 * Cells(i - 1, Ic).Value + 89 * Cells(i, Ic).Value + 84 * Cells(i + 1, Ic).Value + 69 * Cells(i + 2, Ic).Value _
+ 44 * Cells(i + 3, Ic).Value + 9 * Cells(i + 4, Ic).Value - 36 * Cells(i + 5, Ic).Value) / 429
Next i
Exit Sub
NotValidInput:
End Sub
Sub SG_twentynine()
'29 Point Savitzky-Golay Smoothing Filter
Dim Cnum As Integer 'column NUMBER for output data
Cnum = InputBox("Enter column NUMBER for output data (A=1, B=2 etc.)")
For i = (Lrow + 14) To (Urow - 14)
Cells(i, Cnum).Value = (-351 * Cells(i - 14, Ic).Value - 216 * Cells(i - 13, Ic).Value + -91 * Cells(i - 12, Ic).Value _
+ 24 * Cells(i - 11, Ic).Value + 129 * Cells(i - 10, Ic).Value + 224 * Cells(i - 9, Ic).Value _
+ 309 * Cells(i - 8, Ic).Value + 384 * Cells(i - 7, Ic).Value + 449 * Cells(i - 6, Ic).Value _
+ 504 * Cells(i - 5, Ic).Value + 549 * Cells(i - 4, Ic).Value + 584 * Cells(i - 3, Ic).Value _
+ 609 * Cells(i - 2, Ic).Value + 624 * Cells(i - 1, Ic).Value + 629 * Cells(i, Ic).Value _
+ 624 * Cells(i + 1, Ic).Value + 609 * Cells(i + 2, Ic).Value + 584 * Cells(i + 3, Ic).Value _
+ 549 * Cells(i + 4, Ic).Value + 504 * Cells(i + 5, Ic).Value + 449 * Cells(i + 6, Ic).Value _
+ 384 * Cells(i + 7, Ic).Value + 309 * Cells(i + 8, Ic).Value + 224 * Cells(i + 9, Ic).Value _
+ 129 * Cells(i + 10, Ic).Value + 24 * Cells(i + 11, Ic).Value - 91 * Cells(i + 12, Ic).Value _
- 216 * Cells(i + 13, Ic).Value - 351 * Cells(i + 14, Ic).Value) / 8091
Next i
Exit Sub
NotValidInput:
End Sub
Thanks for that.
I have converted it to a user defined function that I find more convenient for these things. The one function will call the formulae for either 5 (default), 11 or 29 points:
Code:
Function Savitzky(Drange As Variant, Optional Points As Long = 5)
'5, 11 or 29 Point Savitzky-Golay Smoothing Filter
Dim i As Long, j As Long  'counters
Dim irows As Long 'Number of rows of data
Dim Res As Double, ResA() As Variant, FactA As Variant, div As Long
Drange = Drange.Value2
irows = UBound(Drange)
ReDim ResA(1 To irows, 1 To 1)
Select Case Points
    Case 5
        For i = 1 To 2
            ResA(i, 1) = CVErr(xlErrNA)
        Next i
        FactA = Array(-3, 12, 17, 12, -3)
        div = 35
        For i = 3 To irows - 2
            Res = 0
            For j = 0 To 4
                Res = Res + (FactA(j) * Drange(i + j - 2, 1))
            Next j
            ResA(i, 1) = Res / div
        Next i
        For i = irows - 1 To irows
        Next i
    Case 11
        For i = 1 To 5
        Next i
        FactA = Array(-36, 9, 44, 69, 84, 89, 84, 69, 44, 9, -36)
        div = 429
        For i = 6 To irows - 5
            Res = 0
            For j = 0 To 10
                Res = Res + (FactA(j) * Drange(i + j - 5, 1))
            Next j
        Next i
        For i = irows - 4 To irows
        Next i
    Case 29
        For i = 1 To 14
        Next i
        FactA = Array(-351, -216, -91, 24, 129, 224, 309, 384, 449, 504, 549, 584, 609, 624, 629, 624, 609, 584, 549, 504, 449, _
        384, 309, 224, 129, 24, -91, -216, -351)
        div = 8091
        For i = 15 To irows - 14
            Res = 0
            For j = 0 To 28
                Res = Res + (FactA(j) * Drange(i + j - 14, 1))
            Next j
        Next i
        For i = irows - 14 To irows
        Next i
    Case Else
        Savitzky = "Points must be 5, 11, or 29"
        Exit Function
End Select
Savitzky = ResA
Exit Function
NotValidInput:
Savitzky = ("Non valid entry- terminating.")
 End Function
To return all of the results enter as an array function:
Enter the formula in the top cell of the output range.
Select the entire output range
Press F2
Press Ctrl-Shift-Enter
Doug Jenkins
Interactive Design Services
Doug. Thank you for this. I hope it helps other users.
