Do you have a sketch? This sound really weird. Usually an LWN is used on a pressure vessel, and has 2 ends; a welding and a flanged end. You want to join the welding ends of 2 LWN's together using an elbow?
Do you intent on using a standard elbow, like B16.9? There are not off-the-shelf elbows for such (weird) configurations available.
What Code are you design to? Whats the application?
