Contact US
INSTRON 5565A Flexural Testing
Hi guys, I have a question regarding using INSTRON 5565A for flexural testing of poly methyl methacrylate (PMMA) resin.
During testing, after 100 seconds the force seems to begin to drop despite the sample not breaking. Does anyone know why this is happening? Is it to do with the settings on the INSTRON Bluehill system?
Any one with ideas is greatly appreciated.
RE: INSTRON 5565A Flexural Testing
All plastics creep.
It shouldn't...unless it's programmed to do that. Did you RTFM?
http://bcodata.whoi.edu/Carrington/Instron_5565_Ma...
That machine supposedly has a limited cycle testing capability, are you sure you are not operating in that mode?
Alternatively, the material is yielding/relaxing/creeping under load and the actual load required for a given crosshead speed really does drop (i.e. it may be a material characteristic). Is the drop repeatable for a given material composition?
Last, yes, you might be exceeding the force output of the machine, or it may be "old and tired" and you are seeing a thermal reset fuse operate - I would expect the machine to give error codes if this happened, though.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
