SyedB.Shah
I need guidance to formulate a methodology to solve the heat transfer problem. I am interested to determine the strength and location of heat source in 1D and 2D domains.
The known parameters include the material conductivity, the geometry of the domain, boundary temperatures changing with time, and insulated boundaries so conduction only.
I have already applied analytical methods but they work on simplified geometry and central position of heat source so there is symmetry in the temperature profile. This means that boundary temperatures will be equal.
I am interested to find the location of a heat source when boundary temperatures are not equal and therefore heat source will be in a non-central position. Also, the temperature inside the domain will be unknown, the problem needs to be solved using only boundary temperatures. I am supposed to look into numerical techniques but some guidance will be really helpful. Please let me know if something is missing from the explanation and not making sense. Thanks
