Drafftsight - Problems with printing out scaled drawing to A1
Problems with printing out scaled drawing.
Keeps coming out too small.
How can I fix this ?
Drafftsight - Problems with printing out scaled drawing to A1Drafftsight - Problems with printing out scaled drawing to A1(OP)
Problems with printing out scaled drawing. Keeps coming out too small. ![]() ![]() How can I fix this ? Thanks Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! Already a Member? Login |
ResourcesThis report will highlight a wide sampling of applications, addressing a range of physical phenomena important to the different designs, spanning component to system design. Download Now
Digital twins—virtual clones of real objects—may be able to reveal valuable insight into the real-world performance of products and processes. However, it depends on who you ask. Download Now
This white paper provides a complete guide to enclosure thermal design, covering all the main points that need to be considered. If you are responsible for enclosure-level thermal design, Simcenter provides a range of thermal design software, allowing you to select a product that is an ideal fit with your company’s thermal design workflow and supply chain needs. Download Now
How much PLM is right for smaller manufacturers? Midsized companies need capabilities but have limited resources. In this eBook, Jim Brown, President of Tech-Clarity, takes you through getting started with the right PLM solution. Download Now
RE: Drafftsight - Problems with printing out scaled drawing to A1
Check for objects on hidden layers, as that will cause the problem. This caused the issue when I tested for it.
One other thing to check is to make sure that there aren't any hidden or non-visible entities in your layout outside of your titleblock that are preventing the drawing from scaling to full page.
One way to check that is to select everything then deselect the titleblock and contents.
Hope that helps
There was a tiny stray element on top right corner I missed.
Removed it, and drawing now fully fills out the A1 page as I intended.
Could not find this solution on Draftsight's very unusually compliacted on-line forum.
So Kudos to you !!!
Thanks so much.
