Different yield displacement values in tension test of an L Panel
I'm verifying my Concrete Damage Plasticity constitutive model using a tension test on an L-Panel. The test is displacement controlled and is applied at the lower right bottom of the L Panel. I am also verifying the mesh insensitivity of sizes 200mm, 300mm and 400mm by using stress-displacement input for tension and exponential softening after yield.
So, when I'm plotting the output Max Principal Stress and displacement I'm observing the yield displacement is different for each individual meshes and yield tensile stress being almost identical. I'm unable to comprehend what's causing different yield displacement as mesh size is varied while it is supposed to be the same. Can someone help?
RE: Different yield displacement values in tension test of an L Panel
Can you attach a picture of your model ? Did you try with more mesh sizes to reach mesh convergence ?
Take a look at PEEQ and PEEQT contour plots to see where the yielding occurs. Maybe these particular areas require mesh refinement.
FEA way,
It turns out I did not do the mesh convergence study for model and the coarser mesh was not sufficiently good. Thanks for the insight.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
