API-650 Stainless Steel Minimum Thickness and Design Temperature
4
Dear Sirs/Madams,
I am a Chemical Engineering and, therefore, not the right professional to specify storage tanks for industrial aplications, but recently I have specified a process data sheet for an atmospheric tank to storage liquid fatty acids at 60 Celsius degree and choose the API-650 12th version as the standard to be addressed. Soon I have discovered the tank design temperature must not be above 93 Celsius degree and my SS304 plates thickness must not be less than 5 mm (3/16").
Please, does anybody know why the standard set these requirements?
Thanks for your help in advance.
Best Regards,
Luís - Brazilian Chemical Engineering (Graduated 86')
RE: API-650 Stainless Steel Minimum Thickness and Design Temperature
Some of the minimum thicknesses are for constructability and maintaining dimensional tolerances. Thinner plate is difficult to butt weld and will warp when welded.
The 93 Celsius is not applicable. The base version of API-650 is limited to that, but it is extended up to 500F in Annex M and also in Annex S.
For larger tanks, minimum thickness will be affected by wind design. For smaller tanks, by handling in the shop.
UL-142 allows some thinner material, but has its own drawbacks that may make it undesirable for this application.
Dear IFRs and JSephen.
Thank you very much for your enlightments.
Have a nice weekend.
Best Regards,
Luís.
I have seen thinner tanks, especially ones made from lean duplex SS, but they had a lot of stiffening rings and other features.
So, less metal but more difficult to build.
lcms, you might direct further questions on this subject to the Storage Tank Forum.
Mike
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
White Paper - Moving to a Driverless Future
This white paper describes what we see as the best practices to support a sustainable engineering process for autonomous vehicle design. It exposes how to use simulation and testing in common frameworks to enable design exploration, verification and validation for the development of autonomous cars at a system, software and full-vehicle level to drive a mature product development process for automated driving. Download Now
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
