Subroutine for coefficient of thermal expansion
Dear all,
I am trying to run a coefficient of thermal expansion subroutine using the UEXP subroutine. For this, like a first step I tried a simple thermal stress analysis on a 0.2*0.1steel bar giving a body heat flux. The calculated stress values are matching with the theoretical analysis. Now instead of giving the thermal expansion as a direct input, I would like to enter the same as a subroutine. The attached subroutine is given below. But the problem aborted due to compilation error. Can anyone help to solve the issue? For the next stage, I have to incorporate the change of volumetric strain and the thermal strain to analyze the phase transformation in welding.
subroutine uexpan(expan,dexpandt,temp,time,dtime,predef,dpred,
statev,cmname,nstatv,noel)
c
include 'aba_param.inc'
c
character*80 cmname
c
dimension expan(*),dexpandt(*),temp(2),time(2),predef(*),
dpred(*),statev(nstatv)
c
alpha = 1.1d-05
c
expan(1) = alpha*temp(2)
c
return
end
RE: Subroutine for coefficient of thermal expansion
Do you have proper version of Fortran compiler installed ? Try the following command to see if subroutines work correctly on your machine: abaqus verify -user_std
You can also use exemplary UEXPAN subroutine available in the Verification Guide (User subroutine verification —> UEXPAN).
You didn't attach the subroutine and copying the unformatted code from your post won't help to answer your question.
The first example in the Verification Manual is basically what you are trying to do. Why don't you take that file and start from there?
Dear FEA way and Mustaine3
THANK YOU FOR THE COMMENTS
Fortran is working fine. I have done welding analysis previously using the DFLUX subroutine.
I have used the same subroutine from the Abaqus manual to verify the code. It is working well with the Abaqus inp file. But showing an error with my inp file. So I changed a few formats in the file from the Abaqus manual and it is working. The corrected file is attached
Now I have to do include the phase transformation change due to volumetric change along with the thermal expansion(epsilon theral+epsilon volumetric). Does anyone have a standard file for the same?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
