Filler electrode for repair welding of Tool steel S5 or 06
I am going to buildup on tool steel s5/06 for repair purposes, i have limited option of using electrodes which includes E8018-B2L and E12018M. I have also E309 and inconel.
From my point of view in order to have good tensile strength i should use E12018M or E8018-B2L (2nd preference).
Please give your suggestions. Thanks!
RE: Filler electrode for repair welding of Tool steel S5 or 06
Most die repairs I have been associated with are welded with GTAW. I have seen SMAW and FCAW used for large forging dies.
Best regards - Al
Mostly SMAW is used in our industry for welding. The part is rotor and its very small. thickness of build up is 7 to 9 mm on dia of 10 mm.
I'd go for a shock resistant filler with similar hardness, preferably on a layer of 307 (18-8-6).
But then again, without knowing the application and operating conditions, not much can be said...
@ gtaw, see attached screenshot from a Budinski book.
https://files.engineering.com/getfile.aspx?folder=...
They've helped me out in the past with custom stainless steel formulations.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
