Wheel blows up when rotating
Hey,
I made a model of a wheel consisting of three different concentric layers, aluminium-rubber-aluminium. Then I have the wheel rotate and in the same time a track approaches the wheel. The wheel is supposed to just ride over the track, but it blows up & deforms (second picture) and even goes through the track.
Does someone know what is going wrong?
RE: Wheel blows up when rotating
Did you define contact in this analysis ? You can use general contact capability. It works best. What are the boundary conditions and how are they applied (it would be best to show them on the picture) ?
Is the deformation scale factor larger than 1 in postprocessing?
Otherwise check if NLGEOM is on.
If that does not solve the problem, run the analysis in double precision.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
