Define Hinge Axis that updates with assembly deformation in abaqus
Hello everyone,
I am looking to model an assembly that rotates and translates in space, it contains a hinge. Can i define the hinge axis such that its local axis (basically the x axis that it rotates about) updates as the assembly moves in space in Abaqus ?
Thanks and Regards,
Mitul Shah
RE: Define Hinge Axis that updates with assembly deformation in abaqus
Use Connector elements - they do this by default. For example the Hinge connector allows one relative rotation of two nodes in a local coordinates system.
Yes, hinge connector will account for this. It combines both JOIN and REVOLUTE connector types. So it joins two points and allows rotation about a single axis. Just keep in mind that you will have to define local coordinate system with X axis along hinge’s axis for this connector. You can use Connector Builder to speed up this process.
I should have better explained the problem.
I am using a connector element for the hinge joint. 2 nodes at the end of the hinge define the hinge axis, the hinge axis is a local co-ordinate system with the x axis aligned to be axis of rotation for the hinge setup.
What I am trying to achieve is the hinge axis updating / moving as the 2 nodes that represent the end of the hinge move in space. What I am noticing is, in CAE, when we define the hinge axis, it does not update the axis orientation as the hinge moves / rotates.
Thanks and Regards,
Mitul Shah
I doubt that. If you have a nonlinear procedure and NLGEOM is active, then the directions of the connector will update.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
