Shell extrude failed
Hi there,
I run the python script but it always shows "p.BaseShell(sketch=s), Shell extrude feature failed", looking for help!
Thanks!
import...
s = mdb.models['Model-1'].ConstrainedSketch(name='__profile__',
sheetSize=1400.0)
g, v, d, c = s.geometry, s.vertices, s.dimensions, s.constraints
s.setPrimaryObject(option=STANDALONE)
s.ConstructionLine(point1=(350, 350), angle=0.0)
s.HorizontalConstraint(entity=g[2], addUndoState=False)
s.ConstructionLine(point1=(350, 350), angle=90.0)
s.VerticalConstraint(entity=g[3], addUndoState=False)
f=open('C:/Users/nerooo/Desktop/works/Contour1.txt','r')
contour=[]
coordinate=[]
data=f.readlines()
f.close()
for xy in data:
temp1=xy.strip('\n')
temp2=temp1.split('\t')
contour.append(temp2)
for i in range(len(contour)):
temp3=contour[i][0].split()
for j in range(len(temp3)):
temp3[j]=int(temp3[j])
coordinate.append(temp3)
s.rectangle(point1=(-100, 600), point2=(600, -100))
for m in range(len(coordinate)):
CoordNum=len(coordinate[m])/2
for n in range(CoordNum):
s.Spot(point=(coordinate[m][n*2], coordinate[m][n*2+1]))
if n:
s.Line(point1=(coordinate[m][(n-1)*2], coordinate[m][(n-1)*2+1]), point2=(coordinate[m][n*2], coordinate[m][n*2+1]))
if CoordNum>2:
s.Line(point1=(coordinate[m][0], coordinate[m][1]), point2=(coordinate[m][(CoordNum-1)*2], coordinate[m][(CoordNum-1)*2+1]))
p = mdb.models['Model-1'].Part(name='Part-1', dimensionality=TWO_D_PLANAR,
type=DEFORMABLE_BODY)
p = mdb.models['Model-1'].parts['Part-1']
s.unsetPrimaryObject()
session.viewports['Viewport: 1'].setValues(displayedObject=p)
del mdb.models['Model-1'].sketches['__profile__']
RE: Shell extrude failed
Make a simple example and attach the needed files here.
Reading the commands and saying whats wrong is rarely possible.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
