Fill Sketch 1
rfer
Hi All,
This is for Creo 4.0.
I feel like this should be a simple task, but I am stuck. I've made a sketch (Model>Datum>Sketch) of a grid of circles on a flat plane. I want to now fill these circles black. Right now they are just empty circles that I have changed the line color to black. However I cannot find a way to fill these solid black.
I would like to open this part with the dot grid as a Drawing and then save that drawing as a to-scale PDF which I will then print. In the Drawing window, I found a Hatch/Fill option (Sketch>Edit>Hatch/Fill). I have been able to successfully fill circles here I have drawn here (Sketch>Sketching>Circle), but these sketched circles are just floating and not able to snap or reference to anything. I can't find a way to use this Fill/Hatch option on a sketch that already exists from the part.
The attached JPG is the view of the plane with the dot grid on it in the Drawing program of Creo. The black dots are what I want to fill solid (ignore the larger blue dots and rectangles).
Thank you for your help!
 https://files.engineering.com/getfile.aspx?folder=1c7d51e5-4653-4071-9ba1-21ff36dbe9f3&file=Dot_Grid.JPG
If you make a cosmetic feature referencing your sketch you can hatch or fill the cosmetic.
Hi dgallup,
Thank you for this advice. This worked well for me.
Have a nice day!
