andradesilva
Materials
I am solving a problem in EES. All my units are in S.I. However, I would like to change Pressure from [Pa] to [KPa] without messing up the results. I tried to do it, but the results make no sense. What is the best way to do it? Also, if I change Pressure from [Pa] to [kPa], are there any dependent units? Area should be changed to [mm^2], or can still be fine in [m]?
Thank you in advance,
Andrade Silva
Andrade Silva
