Abaqus Explicit quasi-static stick problem in contact
I am trying to simulate plastic snap behavior against steel locking feature. However, the plastic snap will stick to the steel. It looks that some plastic part nodes are going under steel part nodes, and general contact prevents them coming back... I have used *SURFACE PROPERTY ASSIGNMENT, PROPERTY = FEATURE EDGE CRITERIA but it doesn't solve the problem. Any proposals which could help?
RE: Abaqus Explicit quasi-static stick problem in contact
Can you attach a picture showing this behavior ? What are the settings of the interaction property (normal/tangential behavior) ? Try using contact pairs instead of general contact and refine the mesh of the slave surface to reduce penetrations.
Also, make sure you have are allowing the parts to separate after contact in the interaction properties.
At least it works now with contact pair definition, thanks!
"Also, make sure you have are allowing the parts to separate after contact in the interaction properties."
I tried to check this from manual, but I didn't find anything related to this. I thought that parts are allowed to separate after contact automatically?
The default value is for this to be checked. Personally I always create the Normal Behavior and Tangential properties in the contact properties dialog just to be sure.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
