I have been reading this forum for a couple of years now and the information has been exceptional. I have been working on residential structures in Montreal for the last 3 years and I have a case where I think we could have a constructive conversation.
English is not my native language, hopefully I’ll be able to make everything clear.
Existing situation:
An existing Shoebox (one-storey building), built around 1930. The foundations are made of rubble bounded with mortar (typical foundation from that era in Montreal).
The building is 20 ft width with a 1-storey building on one side and a two-storey building on the other.
The existing wood joists are supported on the rubble foundation (and on a central axis). We also have 10 inches hollow concrete blocks acting as the fire protection between buildings.
As usual with these type of foundations, the mortal is so brittle that it crumbles with a slight touch.
The project:
To add a floor on the existing building and build a new roof.
The basement won’t be used as a residential area, so I can take space there with new structure without causing a problem.
The challenge:
I don’t want to add another 12ft of hollow concrete block on the existing rubble foundations without making reinforcement. Obviously, safety is my first concern, but I’d like to find a solution that would be economical.
Initial Ideas:
I haven’t made calculations yet, but this is where I am leaning right now.
New Strip footings
1: I’d poor a new strip footing (inside the basement) next to each rubble foundation.
1.1: I’d build a bearing wall on this new strip footing to support the existing floor joists.
1.2: I’d build a bearing wall on the first and second floor to support the new joists.
Questions:
By doing this, can I assume that the live/snow/dead loads from the floors and the roof are not supported by the rubble wall?
Rubble foundation reinforcement
2: I would like to repair/reinforce the rubble wall (even if in reality it will be less loaded than initially). Is there an economical way to do that? By pouring a concrete wall next to the existing foundation? If so, is there a good way to bound the rubble foundation to the new concrete foundation? Do I have to use a special concrete not to cause chemical reaction between the old mortar and the new concrete? Should I link my new strip footings to the reinforcement layer on the rubble foundation?
2.1: My client is going to sell the building after the project. There is no way I can leave the rubble wall as it is right now. Even if I could prove (and I can’t) that it’s strong enough, the look of the wall will create a lot of problems. So I have to reinforce it.
I’d like to hear ideas about this project. Am I on the wrong path? Any improvements I could make? Suggestions?
Thank you very much in advance
Jean-Francois
Existing situation:
The project:
The challenge:
Initial Ideas:
New Strip footings
Questions:
Jean-Francois
