Newbie: shaft / bearing assembly design
I have a project where we need to design a stirring paddle for a cooking vessel. It will not turn quickly. Perhaps 20 to 30 rpm would be good.
We intend to drill a hole in the lid and then insert a shaft with bearings and seal. A 12 or 24 volt geared motor to power the shaft.
The cooking vessel will have a little pressure that needs to be maintained. Around 0.15 Mpa .
I need to know what type of set up we need. What type of bearing and seal would suit this project.
RE: Newbie: shaft / bearing assembly design
