Contact US
Is there a way to infer isentropic temperature coefficient
I have gas properties available from SRK or PR equation of state for mixtures such as
Entropy, enthalpy, Cp, Cv, isentropic volume exponent, density, compressibility.
Question: Is there a way to infer the 'isentropic temperature exponent' from combination of the above properties (by way of a direct formula)?
Objective is to not have to deal with derivatives and all the pain that comes along with them.
Other question:
In Prode properties is there direct access to these properties via DLL call from Fortran?
Life is not about waiting for the storm to pass. It's about learning dance in the rain.
RE: Is there a way to infer isentropic temperature coefficient
pmover,
Thanks a lot for sharing your notes, I appreciate this very much. I had a look at the method, which I think is a method that would help finding the isentropic temperature of a compression process by proceeding iteratively. In my case, I do not have two end points (start and end point of compression path). It is more that I need to find gas properties (secondary) of a thermodynamic state based on pressure, temperature and gas composition.
Actually, I find a way to this.
There are directs formula that for a given (pressure, temperature and gas mixture) establish relashionship:
kv : isentropic volume exponent = F(Temperature, Molecular weight, Speed of sound, Compressibility)
kt : isentropic temperature expoment = G(Pressure, Temperature, Speed of Sound, Molecular weight, Isobaric Specific Heat, Isochoric Specific Heat, Density)
Out of lazyness, I wont write the complete formulas; if someone needs this, please let me know.
rotw,
yes, you are correct in that the isentropic temp is found by interation using an EOS. the notes provided use BWR EOS. my initial search for the code written resulted in only my original notes. 2-hrs later i found the code.
not sure why the two values you seek are needed, but an internet search returned this link/posting
https://www.eng-tips.com/viewthread.cfm?qid=283850
good luck.
pmover,
I need the two values in order to calculate centrifugal compressor parameters (head, efficiency, etc.). I never use k ratio (=Cp/Cv) for this purpose because it is innacurate for real gases ; in this respect, ideal/perfect gas is just particular case of real gas case (k=Cp/Cv=kt=kv) so formulas work too.
Thanks for the link!
yes, you can call Prode Properties from FORTRAN if you wish to verify your derivatives,
another software which comes to mind is, of course, Refprop,
also, you may find useful Bridgeman's tables (for unusual properties)
Paolo
Thanks Paolo. Will take a look at Bridgeman's tables which I did not know of.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
