NX10 Rename Expression 1
jerry1423
It is possible to change the name of an expression in NX10 ?
It has been several years since I needed to rename an expression, but I just can't find how to do it.
I simply want to change the p number to something more meaningful.
In previous versions it seemed to be very easy.
Jerry J.
UGV5-NX11
Select an expression from the list, the "name" and "formula" fields near the bottom of the dialog will reflect the chosen expression. Change the name as desired and OK the dialog.
www.nxjournaling.com
Tools ribbon, expressions button.
Franklin
UG 10,13 & 18
NX 1,2,4,6,11 & 12
NCL502 (yep I love Sequential Mill)
