Removing Plastic piece stuck with Glue on a Metal Groove
Sameel
AE
Hello World!
I am having an issue with a LED Fixture in which plastic piece is stuck on one portion of the groove. I believe this portion was purposely stuck with a glue, as I opened 4 other fixtures, which resulted in plastic piece to be stuck in the same area.
I need advice on how to remove this piece, as I am supposed to get this fixture painted and place another plastic part in the groove space.
Would appreciate a quick response due to time constraints.
Thank you.
