Hydraulics System Issue
Hello Team / Hydraulic experts
We are in a situation as described below.
we have a turret punching machine. the machine is equipped with hydraulic system for rapid punching. the system has a Yuken A37770 Double piston pump. Pump One is supposed to deliver 9 MPA and Pump Two is supposed to deliver 21 MPA . both lines are going to main hydraulic cylinder with individual Accumulators.
Now when the machine is started both the Gauges show same pressure 20 MPA. We tried adjusting the Pressure of One Pump....the output of other pump also changes , either which way....increase or decrease.
thinking that the Pump may have some defect...we replaced the Pump....with Good working pump. but result is same.
the safety valves , release valves are working OK...
what and where is something wrong..? may be the Main cylinder ? or something somewhere is getting blocked or getting open?
any expert comment on this will put us in right direction..?
thanks
thanks
RE: Hydraulics System Issue
Can you use dye to trace leaks through valves?
(Beware that such issues often turn out to be something that you didn't describe.)
Can you post a schematic? Without one we're just guessing and can't help you nearly as well.
If the lines from each pump to the cylinder are common, with no valving to isolate them, then they will have the same pressure in them. Is there something that is supposed to isolate the pumps from each other?
The other thing to keep in mind is that piston pumps are positive displacement pumps, and as such will deliver the same flow rate regardless of how high the pressure rises, until one of a few things happen (depending on how the system is configured): a relief valve opens to vent excess flow, thereby limiting the pressure; the pump destrokes to limit the flow and/or pressure (this applies only to variable piston pumps); something fails (motor stall, shear coupling slips, pump internals break etc). Note that the last one should never happen, but sometimes things don't operate as intended.
