Hello guys,
I am building a small prototype for a Coolant Dispensing System and need to measure the flow rate of water & chemical in the pipe in order to control the opening of valves downstream.
Since I am building a small pilot system, I can't really spend too much money and hence I intend to use those cheap Hall Effect Flow Sensors available online. Accuracy isn't important right now, but repeatability is!
So my question, how do I connect the Pulse Output of the Flow Sensor to the PLC?
- the sensor
- the sensor
