rsbmusicguy
Morning guys,
I am in the process of designing a base plate in LRFD for a guide rail that is bearing against an unknown timber material and am having trouble with compression in the timber on the bottom of the base plate when impacted by a vehicle. The trouble is my compression stress from the moment is great than my allowable compressive strength which is causing it to fail. Additionally, since I am assuming the least strength in compression from the timber this is also contributing to why I can not get it to pass.
Note my bolt configuration consists of four bolts, two above the neutral axis and two below. See attached photo taken from the AISC for the basis of my calculation. While the equation accounts for the force in the bolt from tension, you can use the same basis to calculate the compression below the neutral axis.
The guide rail I am designing is for an extreme event and therefore, I am considering replacing the section modulus (I / c) term with the plastic section modulus (f*I / c). Note the shape factor 'f' equals 1.5 for rectangular cross sections which applies to my case and therefore am considering to use it to increase my compressive capacity.
Any other recommendations on how to approach this problem or issues considering my assumption would be much appreciated.
Thanks!
RSB
Thanks!
RSB
