Extracting real force values from frequency domain vibration analysis
Dear all,
My question is about using Abaqus to predict accurate forces within a vibrating structure. I am carrying out a frequency domain vibration analysis on a tensile test, for my PhD project. Currently I am using the Steady-state Dynamics, Direct Solution procedure as this appeared the best compromise between coping with my boundary conditions and solving time. I wish to know the forces within the structure (and not necessarily the stresses) as I want to compare to a measurement made by a force transducer.
The Abaqus post-processor has a Free-Body Cut tool which, when used with the View Cut manager, can find the free-body force at any planar section. (I had to request NFORC in the Field Outputs to ensure it had the data to work with, so I suspect all it is doing is summing the nodal forces over the nodes nearest the defined plane.)
However, when I use this Free-Body Cut tool a warning pops up telling me:
"Free body computation is based on complex magnitude or phase angle in a steady state dynamics analysis. The result is not physically meaningful."
Which obviously is not a good warning to get when I want to use the simulation to verify the force transducer output (and whether this is a sound thing to do is another question for another day).
I find this puzzling as the kinematic parameters (displacement, velocity, acceleration) are presented as real, physically meaningful values, and the dynamic force experienced by the structure is directly related to the acceleration and the boundary conditions. So why would the force amplitude be any less meaningful? (and of course it is an amplitude, as the analysis is in the frequency domain.)
I should say that I have accurate velocity measurements so I can validate the simulated velocities against those.
So, I guess my questions are:
1. Why can't I take the force (amplitude) values from a Steady-state dynamics analysis as meaningful?; and
2. Should I be using a different Abaqus procedure, and which one? (Should I move to the time domain and Standard Implicit?)
Sorry in advance if this is a trivial question, I just haven't managed to get a straight answer from my colleagues or anyone else I've asked so far. Even though I am surrounded by experts, they all work in slightly different fields (eg exclusively time domain) or have never had to worry about my particlar force problem.
Thanks in advance,
Colin
RE: Extracting real force values from frequency domain vibration analysis
In all steady state dynamic analysis procedures (not only direct but also mode-based and subspace-based) force output is complex number with real and imaginary components. If you want to perform frequency domain analysis there’s no other choice. However instead of using free body cut you can sum nodal forces in selected section. Variable called PRF provides magnitude and phase angle of reaction forces.
Hello FEA_way,
Thanks for your reply, I looked up PRF in the manual and it looks like that's the sort of thing I'm after, except that I need nodal forces rather than nodal reactions.
I think what I really want is to get traction vector on my cutting surface, time the surface area - but I'm not sure how this translates into FE. Looking at the manual this might be what NFORC is, but I'm not sure. The free body tool seems to use NFORC so I could assume so.
There doesn't seem to be an option for P-NFORC so I suppose I could just ignore the warning; there would be a problem if the individual nodal forces were out of phase, but I assume I have steady-state standing waves and all my parameters are in phase.
Anyway, thanks very much for your help.
Cheers,
Colin
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
Modern cars, trucks, and other vehicles feature an ever-increasing number of sophisticated electrical and electronic features, placing a larger burden on the wiring harness that enables these new features. As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - Modeling and Optimizing Wire Harness Costs for Variation Complexity
This paper will focus on the quantification of the complexity related costs in harness variations in order to model them, allowing automated algorithms to optimize for these costs. A number of real world examples will be provided as well. Since no two businesses are alike, it is the aim of this paper to provide the foundational knowledge and methodology so the reader can assess their own business to model how variation complexity costs affect their business. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
