Getting the number of the element of a group
I'm new to FEMAP API tools. I'd like to know how can I get the number of the elements of a group. I'm asking that because I'd like to loop through all elements of a determined group, save the number of these elements on a sheet and get their properties. I'm posting my code below:
Sub external_pressure_load()
Dim ws1 As Worksheet
Set ws1 = ThisWorkbook.Sheets("ExternalPressure")
Dim App As femap.Model
Set App = GetObject(, "femap.model")
Dim grp As femap.Group
Set grp = App.feGroup
Dim olel As femap.Set
Set olel = App.feSet
Dim grID As Long
Dim elID As Long
Dim i As Long
Dim el As femap.Elem
Set el = App.feElem
While grp.Next
grpID = grp.ID
If grpID = 3 Then
rc = olel.Clear()
rc = olel.AddGroup(FT_ELEM, grID)
elID = olel.First()
MsgBox grpID
i = 1
Do While elID > 0
rc = el.Get(elID)
ws1.Range("A" & i) = el
i = i + 1
elID = olel.Next()
Loop
End If
Wend
End Sub
RE: Getting the number of the element of a group
you could renumber the elements in the group (possibly temporarily),
you could export the group as an analysis model.
Thanks! I found out my error. In "rc = olel.AddGroup(FT_ELEM, grID)", I should have written "grpID" instead of "grID".
If you want the total number of elements in a group, the easiest way is to just use the selector toolbar... Change selector entity to elements, change the selector mode to multiple. Make sure only the group you want is posted. Hold shift and click and drag to grab everything in the window. The total number of elements selected will be listed in the Model Info Pane under Selection List.
Hi rbas85,
if you did an external FEMAP API program and has plenty (hundred thousand) of elements in your group, your loop based on olel.Next() can slow down the program execution speed/time. So if you will meet such an issue, you can try to use el.GetAllArray(... ) method. This method records all elements IDs (and other elements data) from the set to regular 2D array and it can increase program speed up to x10 times. I've met it a few times, especially for water static pressure application macro tool.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reliability Verification for AI and ML Processors
Artificial intelligence and machine learning are seeing growing adoption in a wide range of applications. ICs used for AI/ML applications are characterized by large parallel processing computation units, high power dissipation, and complex circuitry that can deliver maximum performance within a strict power budget. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
